Hello everyone. I'm wanting to build a visor using 4 Raspberry Pi Zero W, 4 cameras (2 IR, 2 Thermal) and 2 monitors smaller than 3" each. However, all monitors I can find below that size are all connected in SPI instead of HDMI
. Now the Pi has only one camera input hence why using one per camera (I can use usb but then would lose FPS which is important on a visor. At least it's what I've read online) and I am happy to use the SPI connections.
However, so far no one has been able to explain to me as to how can you connect a switch in order to switch from displaying Pi 1 to displaying Pi 2.
And even Youtube videos explaining how SPI works don't actually give me any ideas as to how can I switch from one to the other.
If anyone could explain to me how it actually works and how can I switch from one to the other (in very lay man terms please) I would very much appreciate it.
Thanks in advance.
