i have 2 transformers—–same type—–15 v 6a —each———made by same manufacturer-- i join the 0 v of each to make dual rail supply of 15-0-15 v 6a --ac--for amplifier
No you cannot get 15-0-15 that way. You should connect 0 of one transformer to 15 of the other. However this will work if and only if the winding polarities have been marked in a consistent manner by the manufacturer.
A better approach is connect the primaries in parallel first (and don't change it later) then connect 0V of first transformer secondary to 15V of other; measure the voltage across the other two ends. It should read about 30V, otherwise swap the secondary of any one transformer.
--The turns on a pair of paralleled secondary must be IDENTICAL----i guess they are same as made by same manufacturer-------
They must be same, however given the fact that a majority of cheap transformers in India are hand wound in small workshop by unskilled labour, I doubt it would be. Why are you asking about paralleling? Your requirement does not need a parallel connection.
cheap transformer rated at 16-0-16 v 6a w.r.t to 2 rails so each rail gets 3a ?
No each will get 6A. Current is not halved in a center tap transformer it's voltage alone.
my main intention of making this--------because 2 16 v transformer cheaper than 16-016 v transf---and i will get 6a on each rail ?
now what do you think can it be done without any issues ?
Could you please rephrase the above sentence and provide a circuit diagram maybe. That will help us better understand your problem and offer appropriate suggestions.
