How would I select all parameter options that contain a certain item without manually scrolling through hundreds of options? For example: I want a microcontroller with USB, I don't care if it has UART, SPI or any other connectivity options, all I care about is USB. Do I have to search through all the options and select everything with USB or Is there a better way?
I know I can use the 'search within results' box, but it never seems to be as good.
