Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
25 MHz spi routing
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: 25 MHz spi routing (Read 2701 times)
exapod
Guest
25 MHz spi routing
on:
November 16, 2014, 03:19:26 pm »
I need to route a 25 MHz spi interface on a two layer board between three device 100 mm apart.
I never routed a spi with this frequency and distance so i would like some advice on what to avoid.
Should i put resistors in series with the signal and design termination resistors?
I will try to route all the signal on the top layer with a solid ground plane under them but to connect three device i have to use vias, what should i avoid?
Thanks for the help
Logged
Scrts
Frequent Contributor
Country:
Re: 25 MHz spi routing
Reply #1 on:
November 16, 2014, 07:34:12 pm »
25MHz is SLOW. You can put series resistors, however you should route SCK wire at least 2x the track width away from the data lines in order to avoid cross-talk. Even 125Mhz is no issue, unless you're targeting DDR designs.
Logged
markb82
Regular Contributor
Country:
Reply #2 on:
November 17, 2014, 08:35:48 pm »
Ditto. Check out the Saturn PCB Design Toolkit for cross-talk calculations. Or:
http://www.eeweb.com/toolbox/microstrip-crosstalk
. And keep the cross-talk between the clock line and any datalines to < -15dB. Series resistors would help slow down the rise time so I would add them (right at the driver, ie mcu for sck, mosi, and at your devices for miso), even a 25 MHz design can have problems if you have a 1ns driver.
Edit:
Since this is likely a 2-layer board?, I think you may need more than 2x the trace width. Or you could put a ground trace (or copper pour) between the clock line and the data lines?
Last Edit: November 17, 2014, 08:41:45 pm by markb82
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
25 MHz spi routing
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
