1mV / 100mV = 0.01 gain, not -100. Use a resistor divider.
If you still need a cleaner signal, you can filter it, but mind you will still be left with the noise in the passband.
Also, try the laptop on battery power, AC adapter disconnected. The adapter often adds a lot of noise for some reason.
