Author Topic: 2x single rail PSU to make a dual rail PSU.  (Read 1819 times)
Offline @rtTopic starter
« on: January 25, 2017, 06:38:49 am »
Hi Guys :)
Any problem with that?
Basically to use a pair of identical single rail variable bench supplies plugged into the same mains
with their output grounds tied together to provide a dual rail output?
I can’t think of a problem, but maybe I’m not considering something.
Cheers!
Offline jeroen79
Re: 2x single rail PSU to make a dual rail PSU.
« Reply #1 on: January 25, 2017, 09:03:36 am »
No problem at all.
Mind that if you tie the grounds (-) together you will have two positive rails.
For a symmetric supply you need to tie one's  + to the other's -.
Offline tron9000
  • Still an Electronics Lab Tech
    • My Hack-a-day project page
« Reply #2 on: January 25, 2017, 09:12:42 am »
  • connect negative of supply 1 to positive of supply 2
  • the positive of supply 1 will by V+
  • the negative of supply 2 will be V-
  • the voltage measured between V+ & V-, should be twice the output of each supply
  • use the connection made in 1. as your 0V for your circuit.
  • measuring from V- to 0V you should see a negative voltage and from V+ to 0V and positive voltage
Partsbox.io - orangise your parts!
"If you're green you can only ripen. If you're ripe you can only rot!"
« Reply #3 on: January 25, 2017, 01:22:50 pm »
Dual rail might suggest one supply is negative, I don’t know. In my case both are positive.
Didn’t think there was a problem.
+12V, +5V, 0, for retro computing. A number of computers that have no -12V supply needed, and a distribution block with all the fuses.
It just appears I can go a little higher quality for cheaper if both supplies are single rail.
Cheers :)
