Author Topic: how can I disable auto-standby on TV soundbar?  (Read 16265 times)
Offline Andaho
« on: October 11, 2015, 01:55:56 am »
I just bought a Philips HTL2101A/05 soundbar, but have discovered a really annoying feature that is built into ALL soundbars sold in the EU... After a period of inactivity, to meet EU regulations, they have to automatically switch off.
This is annoying because I don't want to have to press 2 power buttons when I turn the TV on... I have the soundbar connected via the headphone socket on the TV, so I control the volume with the TV remote. I want the soundbar to just stay on! - surely it doesn't use much power when there isn't any sound being played anyway?
When googling for this problem/feature, there are lots of people complaining about the auto-standby. My particular model states that it goes into standby after 15 minutes of no sound and no buttons on the remote being pressed (there are no buttons on the soundbar itself). The other really annoying "feature" it has, is every time it goes into standby, it resets the volume - so apart from having to turn it back on, I have to turn the volume back up every time I turn it on.
I was first thinking along the lines of having some kind of IR transmitter, automatically sending the volume up command every X minutes (since I have it set to max anyway, and use the TV to control the volume) - but I have no idea how I would do this... so then I was thinking along the lines of how to generate a slight noise on one of the inputs to prevent standby? - or what about a voltage being sent to the digital coaxial input? - or how about shorting out a circuit inside the soundbar?
There must be some kind of "hack" to prevent it going into standby? - perhaps one that could be universally used to prevent any soundbar going into standby?
Does anyone know how I can do this... or can anyone point me in the right direction of how I might be able to achieve this?
Thanks.
Offline Richard Crowley
  • KE7GKP
Re: how can I disable auto-standby on TV soundbar?
« Reply #1 on: October 11, 2015, 03:23:14 am »
There are several projects for popular microcontrollers (Arduino, et.al.) which will generate IR signals.
Is the soundbar gadget reacting to SPECIFIC IR codes, or simply to ANY kind of IR signal?
You could test it with an IR remote from some other appliance and see if it keeps the soundbar awake.
If it is just reacting to the presence of ANY IR signal, you could make a very simple and cheap circuit with an IR LED and a 555 timer chip to send an IR pulse every 10 minutes, etc.
Offline Andaho
« Reply #2 on: October 11, 2015, 03:45:17 am »
Thanks Richard,
No, it's not any IR, it needs to be one of the remote's codes... I'm aware of the Arduino projects for acting as a universal remote... but buying an Arduino especially for this purpose seems a bit overkill... in my searching I also came across methods of using a mobile and an IR led on the headphone socket, and WAV files that send the command... but again, it seems a bit overkill for the job :S
I do like the idea of a chip more advanced than the 555 chip, that I could program with the code... but I have no idea what chip you can program like that, or how to program it :S - nor do I have anything to read the codes sent from remotes... I was thinking that there would be an android app that can read them - since a camera can pick up the IR - I expected to be able to find an app to tell you what the code is... but I haven't been able to find anything. EDIT/UPDATE - having looked at a remote's IR flash through my mobile's camera, I can see why there isn't an app for it - it's far too fast for the camera to capture!
I am very much a beginner... but eager to learn... I don't like the idea of using an Arduino for it, just because it's so overkill for the purpose... not because of the cost, but just because it's overkill... and I'd like to learn how to do it at it's most simple... but having said that, if there's an easier way to accomplish this task (other than simulating the IR), that would be cool too... I'm thinking along the lines of something like a high-pitched tone generator (that humans can't hear), that I could plug inbetween the TV and the soundbar to simulate a constant sound - thus preventing it from going into standby?
« Last Edit: October 11, 2015, 03:52:44 am by Andaho »
Offline Andaho
« Reply #3 on: October 11, 2015, 10:24:29 am »
After doing a little more research, I think a simple solution of programming an old universal remote with the 'volume up' button, and having a simple 555 timer 'push' the button every ~10 minutes would be a perfect solution...
I'm struggling to find a guide on how to make this kind of circuit... would I have to use a relay to 'simulate' pushing of the button on the remote? - I assume I can just connect wires to the contacts of the button I want pressed?
  • KE7GKP
« Reply #4 on: October 11, 2015, 11:06:25 am »
You can probably use a FET transistor across the desired button.  When you put voltage on the gate of the FET, it will conduct and simulate a button push.
You will need to interconnect the ground of your 555 "finger simulator" circuit to the ground bus of the remote control.
But if your scheme raises the sound level by one "click" every 10 minutes, won't the volume be at "full blast" when you go to turn it on tomorrow?
Offline Andaho
« Reply #5 on: October 11, 2015, 11:11:34 am »
The volume being max isn't a problem, because I want the soundbar at full volume - because I control the volume with the TV. Thanks for your advice.. I continue my research and looking into FET transistors now :)
Offline Jope
« Reply #6 on: October 11, 2015, 01:15:59 pm »
I can tell you what I would use: an ATtiny microcontroller acting as a remote. To receive IR signals from the original remote you need a IR receiver IC like a TSOP38238 (they come in multiple varieties: http://www.vishay.com/ir-receiver-modules/).
I you want to go the route of pressing a button on a universal remote: for this purpose I would use a 4066 analog switch IC (controlled by an ATtiny).
Offline German_EE
« Reply #7 on: October 12, 2015, 01:54:21 am »
There has got to be a connection at some point from the L&R audio inputs to the CPU so that the audio can be detected and the timeout counter reset. Find this point (a scope is all you need) and then feed an audio pulse in there every five minutes or so.
Warren Buffett
Offline PTR_1275
« Reply #8 on: October 12, 2015, 02:24:11 am »
Would another way of "seeing" the original remotes signal be to connect a scope to the leads of the IR led on the remote? Single shot capture it and then work it out from there?
In terms of the hardware, I can't issue any help sorry. My sub on the home theater turns on / off automatically based on input levels which gets annoying. It turns off after about 5 minutes but needs several seconds of signal to turn on. When watching a movie sometimes the sub will turn off then turn on halfway through a bassy scene. I might crack it open and have a look what is inside.
Offline Jope
« Reply #9 on: October 12, 2015, 02:54:42 am »
Of course, provided he has a scope. But I doubt that.
« Reply #10 on: October 12, 2015, 03:18:00 am »
Open it up, and see where the audio goes to the MCU as a sense signal, then disconnect that and feed it some audio signal, probably simply mains hum from the transformer, fed via a 10n capacitor with a 47k series resistor, and that should fool it into staying on all the time.
  • KE7GKP
« Reply #11 on: October 12, 2015, 03:21:55 am »
You don't need a scope.  There are several publish projects that will "learn" the IR code (via an inexpensive IR receiver) and then reproduce the IR code on demand.
Offline ez24
  • L.D.A.
« Reply #12 on: October 12, 2015, 03:28:09 am »
Are there any universal remotes that can be programmed to send a signals based on set times?
Seems there would be a market for such a device.
« Last Edit: October 12, 2015, 01:59:44 pm by ez24 »
YouTube and Website Electronic Resources ------>  http://www.eevblog.com/forum/other-blog-specific/a/msg1341166/#msg1341166
Offline tec5c
« Reply #13 on: October 12, 2015, 01:13:37 pm »
Seems there would be a marked for such a device.
I would have thought so too, but a quick search turned up with no results.
Would a simple 555 timer as a PWM connected to a button inside a universal remote not do the trick? If volume up is of no concern to you, a PWM signal to this button to simulate a press every X amount of seconds would suffice, no?
Offline Chris C
« Reply #14 on: October 12, 2015, 07:37:56 pm »
I have a FM transmitter that would shut off after just a few seconds of silence.  Very annoying.
I tried mixing in a continuous ultrasonic signal.  That kept it from turning off, without much amplitude.  But it sometimes heterodyned with components of loud music, creating audible beat frequencies.  A subsonic signal worked too, but required substantially more amplitude, which caused other artifacts.  Several variations on these themes were tried, but I couldn't find anything that was 100% inaudible.
Eventually I tried connecting every pin on the MCU to GND or VDD via a 10K resistor.  Since providing an audio signal would turn it on, I quickly found the sense pin.  It didn't even require a changing input, simply tying it to VDD through the resistor was sufficient.
Offline Andaho
« Reply #15 on: October 13, 2015, 03:13:01 am »
Thanks for all the replies and suggestions :)
Yeah, I do actually have a harmony 300 remote stashed away, and I'm aware that it can be programmed to turn on multiple devices with the power button, but the layout of the harmony isn't great for virgin media (a tivo box)... I have my tivo remote programmed to control the TV, so that's the only remote I use...
Every time this stupid soundbar goes into standby, it 'resets' the volume to a 'normal' low volume... so it's not just the annoyance of having to turn it on with the TV, but also having to turn the volume back up - that takes more than a few seconds holding the volume up button.
I've actually decided to pull apart the soundbar, and the TV... I've disconnected the TV speakers, and re-wired the TV straight to the soundbar speakers (so in effect, replaced the internal TV speakers with the soundbar speakers - not using the soundbar amp at all)... the max volume doesn't quite go as loud as before (which isn't a problem, because it's only for TV viewing), but it still sounds great...
The only thing I'm a little worried about:
Is it possible that these better speakers (from the soundbar) will be drawing too much from the TV amp? - or would that only happen if I turned the volume up too high? - or is it even possible to damage an amp by connecting more powerful speakers to it?... At the moment it's working (practically) as a perfect solution.
« Last Edit: October 13, 2015, 03:15:40 am by Andaho »
  • KE7GKP
« Reply #16 on: October 13, 2015, 04:27:28 am »
Yes, it is possible that the speakers in the sound bar are lower impedance than the internal speakers in the TV.
So that makes the audio power amplifier chip inside the TV work harder, and raises the possibility that it could be burnt out.
I would be rather wary of this "solution" for this concern.  At least I would attempt to identify the audio power output amplifier chip inside the TV and monitor it for excessive temperature rise during operation.
« Reply #17 on: October 13, 2015, 05:00:26 am »
No, the TV speakers will be 8R speakers, and the sound bar will be roughly the same. The audio amplifier in the TV will drive it without a problem, though if you listen at full volume you will probably overheat the TV amplifier, they are never cooled properly to handle that.
So keep the volume below maximum.
jusat look at the speakers on the TV set, and those in the sound bar. Probably both sets will be marked 8R, so will work.
