The 3 connections are +, - and BSI (Battery Size Indicator, or sometimes Battery Sensor Indicator)
It's a resistor which the phone can use to detect the battery size.
eg, 5k might indicate 1Ah and 10k might indicate 1.5Ah for example.
So yes, you can just ignore the BSI pin.
