i don't see how a zener used to protect the gate of as mosfet is a crime
Protection is not a crime but assumption that mosfet gate voltage can be exceeded in
linear supply is sign that you do not understand how linear supplies/regulators work. Basically you accused Audioguru of spreading BS w/o proper understanding what actually he is talking about.
low current switcher can be easily filtered down to virtually no noise , so i can't see a crime there either.
Well well. Whole essence of linear supplies and big, heavy mains AC transformers used is to avoid switching noise, bring regulation into low, AC mains 50/60hz frequency domain. If noise can be easily filtered in the regulation circuit, then it can be easily filtered in the power circuit as well - using much smaller inductors than that big heavy transformer. Think about it. Do you even know what is inductor parasitic capacitance and how it affects ability of filter to do actual filtering? Of course it is crime to introduce switching regulator into
pure linear supply unless it is not a part of output regulation.
but after your last post i'm pretty sure you have a major gap in understanding of a mosfet as a series pass element...
No a lot of understanding is actually required to comprehend that MOSFET in linear supply is not used as a switch. Power transistors in linear
regulators are never widely/fully open because there always shall be some voltage headroom for
regulation - in case mains (input) voltage drop. So your "voltage drop Vds of few millivolts" when we talk about linear regulator is BS instead.
