I'm working on building a current limited bench power supply at
http://electronics-diy.com/30v-10a-variable-bench-power-supply.php.
Schematic;
One thing that I've found so far is the power rating of R7 should be high as it is dissipating power at high output levels.
The major problem I'm having is that I keep frying at least one of the output transistors when testing with a 2.2Ohm load at 20V output.
This should draw about 9 amps when not current limited. I'm using 4 3055s and believe that it must be within spec even if I use a single transistor - with current limiting set at ~3 amps.
Check the SOA at
http://www.onsemi.com/pub/Collateral/2N3055-D.PDF. Current unregulated voltage is ~32VDC.
Here is a capture on the scope;
The first channel is the voltage drop across the ~0.24 ohm shunt resistor and second channel is the output voltage after applying the load.
The limiting seems to work nice to me - voltage drops to about 10V after 300us.
BTW after working and blowing some trannies, I put a random inductor to limit instantenous current, here it is for reference;
The scope result is with this inductor in place, and from one of the initial tries before frying a transistor. The inductor does not resolve the problem
but clears irregularites on the scope as expected. I cannot repeatedly apply the load and prevent frying them. Shorting the output immediately
kills transistors ~70% of the time, which I want to prevent.
What do you suggest? How can I protect the output transistors and what is the possible cause of this behaviour?
