I didn't wire anything, have an idea about how thick the wires are but no real number (was 7 when the place was built). I can tell you they have done a baaad job, but it seems that at least the wires are ok.
They are single strand, but about 3-4mm in diameter.
I've done some research, and it seems the transformers are out of question. Too big, too expensive, too much hassle, for nothing.
I checked with the company's website, and it's infact six times 16 amps per branch, as you said. Which is perfectly fine for everything...
Unless you account that I have no three-phase outlets anywhere, and only one strand goes to e.g. 2 rooms. That means, if I turn on the heater, or the oven, and my pc at the same time, the circuit will break. Not to mention the sewer pump being on the same strand as the kitchen. Which I found out and rewired.
I'd draw a diagram, but I think it's easy enough to explain: One fat main cable from the company to me, branches into 4, one is neutral, other three have circuit breakers (fuses) limited to 16 amps (per floor). Then goes the big box which tells which rooms, lights, etc. are connected to which phase. The problem lies in the fact that whoever did the wiring did a horrendeous job of not getting all strands to some crucial locations, like the kitchen, or at least making some outlest in the room on one phase, and others on the other. Instead, I have a situation in which 2 rooms are wired together, and can't be rewired without breaking the walls (brilliant). The whole kitchen, and the living room, and the bedroom is wired together on one single phase. Insane.
So I've found a chart online:
http://www.elteh.net/el-instalacije/tablice-limitatora.htmlMine is the lowest in the biggest chart, I have the 16/16/16 times 2, that'd be 11,04 kW x2. on 6 strands. Which means that while most of the power is useless, when you have to use for example 20 amps in 2 rooms which are wired together, boom nope. Terrible. And the kitchen too. Considering that my old place, a 100 year old building now, has the better wiring and, I think doesn't even have a company limit... sigh
And to upgrade, I'd have to cash out around 250/300 euros per 1kW, and it's only available from these options. The first table is the single phase. It might be possible to switch to that, seeing that due to the horrendous wiring, it's that or the rewireing the whole place. Which is .. you know.. really bad.
As i said, even if the wires were only 2mm, it's still enough for 20 amps or so, and they are deff. around 3 or 4 mm. Only prob is that they are really really badly connected, just in twists and insulating wire. That needs to change fast, I think.
So everyone, thank you very very much for helping me sort this out. I think I can do it from here on. Really, thank you all.
