Some boards that use thruhole caps are designed to support alternative cap sizes, like 3.5mm and 5mm lead spacing, and so have holes for both options (one hole is common). It seems usually the unused hole is filled with solder.
Is there a real reason for it being filled, or is it just a side effect of wave soldering?
