The key requirement on the dehumidifier is the over current protection.
The hint is that fold back style may not work.
This probably means that the element will "try" to draw more than 2 amps initially and draw less as it gets going.
Constant-current style limit supply will limit the current to 2A by lowering the voltage and increasing it as the current draw lessens.
The foldback style may get stuck low after the initial overload, which is good protection for the pass transistor in the supply, but not useful for this particular application.
The e-bay listing only says that there is overload protection, so you can't tell.
A clue is that it supports 100-240v input, so it is very likely a switcher. Maybe somebody will know what style of current limit typical wall-wart switcher uses.
