Author Topic: 4013 flip flop, which pins to ground?  (Read 2059 times)
Offline Chris WilsonTopic starter
  • Race car engineer, dog lover, hoarder.
« on: July 26, 2015, 12:44:13 am »
I have built this circuit, and I am unsure which pins on IC4, a 4013 D type flip flop, should be grounded.
Unused pins are 8, 9, 10, 11, 12 and 13. Should I ground 8, 9, 10 and 11?
I don't know if just the unused data input pin should be grounded, or the unused clock and asynchronous input pins as well.
Thanks.
« Last Edit: July 26, 2015, 05:55:21 am by Chris Wilson »
Best regards,
                 Chris Wilson.
Offline Andy Watson
Re: 4013 flip flop, which pins to ground?
« Reply #1 on: July 26, 2015, 07:00:15 am »
Yes, ground all unused inputs.
« Reply #2 on: July 26, 2015, 10:57:24 am »
Thanks for the fast replies. Someone on another forum has also answered another query, when I powered the circuit up with just the 12V low voltage circuits connected, and I was about to switch on my sig gen to replicate a TX from my transceiver, I noticed a poor sine wave of low amplitude on my scope. I couldn't understand how it was showing an oscillating signal without the sig gen connected. Now I know the likely cause! The CMOS stuff has a very high input impedance and floating inputs are prone to self oscillate :)
The trip LED would also spontaneously come on after a minute or two of running with what appeared to be good square waves to the gates of the FET's. The FET's were not switching HV, in fact I have not assembled the RF side of the FET's yet. I am hoping this will also be cured by grounding the unused pins.
Thanks for confirming which ones I need to ground!
Best regards,
                 Chris Wilson.
