Hello.
I have been working on a design for a microphone preamp in my studio but would also like to make a small linear power supply for it too. It needs dual +/-15 rails as well as a 48V output for phantom power. It also needs power filtering to prevent any unwanted RF junk in the circuit.
I use the waterfall analogy for understanding how electrons fall out of jugs of water (supply) before they splat to the floor (ground), unless diverted by special pipes (copper wire) to do work for us. But I'm having trouble understanding how it works if I have two transformers that are "floating" and using a common ground (chassis) as a ground reference. Also, I can't get it round my head that I can have the 48V power supply connected to the same chassis ground as the +15/-15 rails, if ground is half way inbetween. I know it is isolated with a transformer, so it should be able to 'float' 48V there, but won't other equipment connected to the chassis ground see some voltage difference? Or is it fine, since they are all connected to the houses 'Earth' ground anyway?
Questions:
(1) Some circuits with toroidal transformers connect the middle of the secondary windings both to chassis ground. Would this not inject 50Hz hum and other noise into the circuit ground? As I understand it, noise in a ground is actually not that bad, as long as all circuits have the same reference with no ground loops inbetween. (attachment 2)
(2) Is it possible to have two bridge rectifiers both connected to ground but used to provide a dual power supply? This is how I have it set up in my circuit (in attachment 1.)
Thanks in advance for any help.
EDIT: P.S. Will it release magic smoke? That was the first question I wanted to ask. I've built a cheap and crappy 13.8V power supply before but never one with two transformers or a dual supply.
