below is the code, max time I found was 160us, when key in postion 4,4 is pressed.
Time is measured from start of isr to end of isr as u can see in code.
#include "TimerOne.h"
const uint8_t no_key = 0U;
const uint8_t keys_val[4][4] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
volatile uint8_t key_main_access;
volatile uint8_t key_state;
volatile uint8_t old_col;
volatile uint8_t new_col;
volatile uint8_t new_row;
volatile uint8_t main_read;
volatile uint8_t main_interrupted;
volatile uint8_t key1;
volatile uint8_t key2;
const int row_1 = 33;
const int row_2 = 35;
const int row_3 = 37;
const int row_4 = 39;
const int col_1 = 41;
const int col_2 = 43;
const int col_3 = 45;
const int col_4 = 47;
volatile uint32_t old_time, new_time, diff = 0U;
void setup()
Serial.begin(9600);
/* init all vars for keypad in default state */
init_all_vars__key_c();
/* 20ms timer interrupt */
Timer1.initialize(20000);
Timer1.attachInterrupt(isr_key_callback);
/* all colums inout high */
pinMode(col_1, INPUT_PULLUP);
pinMode(col_2, INPUT_PULLUP);
pinMode(col_3, INPUT_PULLUP);
pinMode(col_4, INPUT_PULLUP);
/* all rows output HIGH */
pinMode(row_1, OUTPUT);
pinMode(row_2, OUTPUT);
pinMode(row_3, OUTPUT);
pinMode(row_4, OUTPUT);
digitalWrite(row_1, HIGH);
digitalWrite(row_2, HIGH);
digitalWrite(row_3, HIGH);
digitalWrite(row_4, HIGH);
void isr_key_callback()
//old_time = micros();
uint8_t check;
if(0U == key_main_access) /* if main is not accessing keypad variable, will happen if main wants to reset keypad varaibles */
if(0U == key_state) /* ground all rows & check for any col low */
digitalWrite(row_1, LOW); digitalWrite(row_2, LOW); digitalWrite(row_3, LOW); digitalWrite(row_4, LOW);
if(!digitalRead(col_1)) /* if found store the col & move to next state */
old_col = 1U;
key_state = 1U;
else if(!digitalRead(col_2))
old_col = 2U;
key_state = 1U;
else if(!digitalRead(col_3))
old_col = 3U;
key_state = 1U;
else if(!digitalRead(col_4))
old_col = 4U;
key_state = 1U;
else
else if(1U == key_state) /* ground one row at a time & check for col low */
check = 0U; /* assume row 1 is found to be low */
digitalWrite(row_1, LOW); digitalWrite(row_2, HIGH); digitalWrite(row_3, HIGH); digitalWrite(row_4, HIGH);
if(!digitalRead(col_1)) /* if found store the col & row */
new_col = 1U;
new_row = 1U;
new_col = 2U;
new_row = 1U;
new_col = 3U;
new_row = 1U;
new_col = 4U;
new_row = 1U;
else
check = 1U; /* initial assumption that this row found to be false, so now check next row */
if(1U == check) /* repeat same as row 1 */
check = 0U;
digitalWrite(row_1, HIGH); digitalWrite(row_2, LOW); digitalWrite(row_3, HIGH); digitalWrite(row_4, HIGH);
new_col = 1U;
new_row = 2U;
new_col = 2U;
new_row = 2U;
new_col = 3U;
new_row = 2U;
new_col = 4U;
new_row = 2U;
else
check = 1U;
check = 0U;
digitalWrite(row_1, HIGH); digitalWrite(row_2, HIGH); digitalWrite(row_3, LOW); digitalWrite(row_4, HIGH);
new_col = 1U;
new_row = 3U;
new_col = 2U;
new_row = 3U;
new_col = 3U;
new_row = 3U;
new_col = 4U;
new_row = 3U;
else
check = 1U;
check = 0U;
digitalWrite(row_1, HIGH); digitalWrite(row_2, HIGH); digitalWrite(row_3, HIGH); digitalWrite(row_4, LOW);
new_col = 1U;
new_row = 4U;
new_col = 2U;
new_row = 4U;
new_col = 3U;
new_row = 4U;
new_col = 4U;
new_row = 4U;
else
check = 1U;
if(0U == check) /* a row low has been found */
if(new_col == old_col) /* if new column & old colum has been equal */
if((new_col >= 1U) && (new_col <= 4) && (new_row >= 1) && (new_row <= 4)) /* if new col & new row are within array boundaries */
if(0U == main_read) /* if main is not reading the key state */
key1 = keys_val[new_row-1U][new_col-1U]; /* store the key value */
else
key2 = keys_val[new_row-1U][new_col-1U]; /* mainline got interrupted */
main_interrupted = 1U;
key_state = 2U; /* key found successfully, now move to next state */
else
key_state = 0U; /* if new col & new row are not within array boundaries, something wrong, move to default state */
else /* if new col & old col are not same, something wrong, move to default state */
key_state = 0U;
else /* if no row low has been found, something wrong,move to default state */
key_state = 0U;
else if(2U == key_state) /* wait for all keys to open again, by grounding all rows, & wait for col to be high */
if(digitalRead(col_1) && digitalRead(col_2) && digitalRead(col_3) && digitalRead(col_4))
key_state = 0U; /* all col found high, move to default state */
else
/*new_time = micros();
if(diff < (new_time-old_time))
diff = new_time-old_time;
Serial.println(diff);
void loop()
uint8_t temp;
while(1)
temp = key_read();
if(no_key != temp)
Serial.print("KEY: ");
Serial.println((char)temp);
uint8_t key_read(void)
uint8_t temp;
main_read = 1U; /* set var for main line read & read the key value */
temp = key1;
key1 = no_key;
main_read = 0U;
if(1U == main_interrupted) /* if main line gets interupted, again read the key var */
temp = key2;
key2 = no_key;
main_interrupted = 0U;
return temp;
void clear_key_vars(void)
key_main_access = 1U; /* clear all previous key varaibles & start aagin */
key_state = 0U;
old_col = 1U;
new_col = 1U;
new_row = 1U;
main_read = 0U;
key1 = no_key;
key2 = no_key;
key_main_access = 0U;
void init_all_vars__key_c(void)
key_main_access = 0U; /* init ll vars to default state */
key_state = 0U;
old_col = 1U;
new_col = 1U;
new_row = 1U;
main_read = 0U;
key1 = no_key;
key2 = no_key;
