Big improvement, it's now usable:Essentially by doing what I told not to do
- All the OpAmps are now connected to +12V and 0V
- The virtual ground is connected between the pots. This is not needed in theory:
-All the Vouts are more stable: "latches".
-There's a bit more range.
- Having the +6V via a separate 10k voltage divider works MUCH better.
- All the the pots were "burned in" after I noticed (nearly fudged up) that putting them in series on 12V 2amps for a couple of minutes reduced their variability.
- I then paired them to within 3%.
- Only one pot is still out of speck (1125 Ohms) - so 'ill keep it for "unpaired" work.
741 side:
- Vout 1: +5.86V to +4.5mV.
(+5.81V usable)- Vout 2: -4.04V to -0.7mV.
(-3.97V usable)358 side:
- The ground is used as -Vcc... I'm a rebel.
- Vout 3: +4.72V to -1.5mV.
(+4.70V usable)- Vout 4: -5.99V to -2.7mV.
(-5.93V usable)There's a few tests to run still but the
358 for the Vout 741 for the virtual ground combo is the best so far
I think the imbalance between the positive and negative is due to the slight difference between pots.
This probably can be solved via trimmer on their inputs.
