I was at a surplus store over the weekend and found a stepper motor specced at 0.45 deg/step. Figured it might be worth picking up as I've been toying with the idea of having a play with a CNC system. But taking a closer look, it had 10 leads coming out the end. A quick google search revealed that there are such things as 5 phase steppers. I'm not sure if this really is one though. The only material I found on the net says that the 5 phase models run at 0.72 deg/step, which isn't a nice multiple of 0.45 deg/step. Also, I gave the shaft a turn and found that it turned easily, with no cogging - completely different from steppers I've handled before.
Assuming it really is a 5 phase stepper, anyone know if I'd need a special driver for steppers like these? I'd really rather not try to build my own given how many options are already out there for stepper motors.
