hmm, just noticed something in simulation.
If I hook power directly to the trigger going into Arduino for pin 8 (left side), then turn it to full on, it cycles once and then off. Power still applied. Then, leaving power on the left applied, i click the right toggle switch to on. Both sides sequence, then stay lit.
Then, if i turn on and off the right side, the left side sequences, right side stays on steady. If I leave the right side in Off position, left lights then stay off, right side on steady. If I leave right side in On Position, Both Sides stay on steady. This is true for operating switches on both sides. Same result is happening, just switched sides.
So, something weird is happening.
If I leave both switches in off position, I turn on the left, left side sequences and stays on steady. If I toggle it on and off, it sequences over and over again, as long as I keep toggle the switch.
There may be something wrong with the simulation, but, if there is not....when brakes are applied, this could screw everything up.
For example, if I have on Left turn signal, I then applied the brakes, the flashing will switch to steady on, and the right side will sequence. That's bad.
If the simulation is right, then something is going on in coding. Or maybe another line needs to be added?
And MC, I appreciate your input, as well as the other posters. Everyone who has replied to this thread, I am thankful for. Don't let others upset you. Post your opinions, I welcome all. I'm a newb. Besides, arguments are good, helps me understand the differences. Just do it without flaming each other
