If the signal to be amplified is independently generated it can be referenced to the virtual ground.
More significantly, most op amps do not operate right up to the supply rails. The supply rails usually should have some margin beyond the swing of the output voltage. Depending on the amplifier a +/- 2 V output with a +/- 2.5 V supply may work, but it is not leaving much headroom.
