Flyback is the name of the circuit at the right (transistor and transformer) which elevates the voltage.
The first 555 marks the intervals between high voltage pulses, the second marks how long that bursts last and the third one drives the high voltage circuit.
If you had only the third 555 (with pin 4 connected to v+ of course) you'll get a continous high voltage output at the secondary of the transformer.
