Hello,
I am building a small solar charger to power a weather station console and I am using the
following circuit:
It works well but I need to make a change.
I will be using a 500mA solar panel together with a 12V SLA deep cycle battery.
The circuit will stop charging the battery when the voltage rises above 14.9V and
will restart charging when the level drops below 12V.
The problem is that whenever the circuit gets powered up, it always starts in its
charging mode.
I know that SLA batteries need a constant charging voltage but because I don't
have a powerful solar panel I will do the following: I will charge the battery with
17V from the solar panel until the battery level reaches 14.9V and then I will
apply a constant floating voltage of 13.6V for the rest of the day. When the sun
sets, the whole charging circuit will switch off, dissipating only 140uA. I have
already made another circuit for that. Now, when the sun rises again, I don't want
to charge the battery again until it discharges down to 30%-40%, so I need the
charging circuit to be in the 'dumping' state. Here is the problem because it always
starts in the charging state.
- Is there a way to start the above circuit in its 'dumping' state instead of the charging?
- Another way would be to short pin 6 to 5V for a fraction of a second, when the circuit
is first powered on. Can you think of a component or a small circuit that would short
pin 6 to 5V for a fraction of a second automatically and then disconnect? (Pin 6 is at 2.8V)
Finally, charging voltage for an SLA should be 15V at around 25 Celsius.
Do you think that applying a 17V voltage until the battery reaches 14.9V would damage it?
Thank you!
George.
