Author Topic: 555 timer frequency increasing/decreasing  (Read 2988 times)
Offline just5554Topic starter
  • Country: lt
« on: February 18, 2016, 04:23:38 pm »
Hi, I want to make circuit with 555 timer, that when i press one button frequency increases, and when i press another, freq. decreases.
I need that for my LM317 project, so I could control voltage with buttons. Thank you! Sorry for my maybe awful English. Just say something where to find or what components I should use.
Offline Dave
  • Country: si
  • I like to measure things.
Re: 555 timer frequency increasing/decreasing
« Reply #1 on: February 18, 2016, 04:28:26 pm »
Get a microcontroller.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
  • Country: lt
« Reply #2 on: February 18, 2016, 04:34:28 pm »
I also though about something like arduino, well i think i will have to use it :)
Offline Zero999
  • 0999
« Reply #3 on: February 18, 2016, 07:31:35 pm »
Yes, a microcontroller will be able to do that.
Just wondering; what does this have to do with an LM386?
Offline Leestons
« Reply #4 on: February 18, 2016, 07:47:11 pm »
Who mentioned a LM386?
Offline Zero999
  • 0999
« Reply #5 on: February 18, 2016, 07:53:22 pm »
Sorry, I meant LM317.
What does a variable frequency 555 timer oscillator have to do with an LM317?
Offline Aodhan145
« Reply #6 on: February 18, 2016, 09:26:08 pm »
Maybe he was going to control the adjust pin with PWM and a filter?
Only thing I can think of.
Offline Zero999
  • 0999
« Reply #7 on: February 18, 2016, 10:10:06 pm »
That's PWM which is different to just changing the frequency.
It will work but the microcontroller will need to be powered from a fairly accurate power supply voltage and the filtering must be good enough to avoid noise being coupled to the LM317 output.
