Can't really see the colors on the resistors that well, but here's how i checked color codes when I started.
Black Brown Red Orange Yellow Green Blue Violet Gray White
0 1 2 3 4 5 6 7 8 9
If you get out your calculator or number pad, counting along as you say the colors helps.
First stripe - most significant digit (example in a 10,000 ohm resistor it would be the 1, brown)
Second stripe - next digit (In a 2700 ohm resistor this would be the 7, violet)
Third stripe - the power ten is raised too, or the number of zeros following the first two digits whichever is an easier way to think of. (in a 3300 ohm resistor this would be a 2, red)
Fourth stripe - tolerance. (gold silver or missing unless its a precision resistor. gold is +- 5%. silver +-10%, none is +-15%
Pneumonic device big boys race our young girls but violet goes wild works (theres a politically incorrect one we used).
