Author Topic: [HELP] parts or circuit to control 5v rail with min loss  (Read 490 times)
Offline allenpan
« on: March 21, 2016, 11:55:03 pm »
long story short: I have MCU that use 2.1v for GPIO, and i have a separate 5v circuit, i would like to use the 2.1v logic to switch 5v on an off... (5v will be up to 200mA, typical 100mA)
feel free to suggest other parts or circuit..but simple with min part counts
i did explored
BJT (2N3904): problem, the Vce has 0.6v drop at 200mA
Enhanced n-MOSFET: problem, Vgs threshold = 1.8v-2.1v too close to my logic voltage, and Vds = 0.6 drop as well...
any other suggestion? i was thinking get another controllable voltage regulator, but i dont know if that is good idea or put too much load on the 3.3v rail..
-Allen
Offline ovnr
  • Country: no
  • Lurker
Re: [HELP] parts or circuit to control 5v rail with min loss
« Reply #1 on: March 22, 2016, 12:17:32 am »
Use a dedicated PDU IC, like the TPS22929D?
Alternatively, just use a BJT to control your FET. Or a cheap gate driver.
Offline soligen
« Reply #2 on: March 24, 2016, 02:31:22 am »
The AO3400 has a Vgsth under 1.5V.
