Author Topic: 555 with discrete components...  (Read 19016 times)
walterdelbono
  • Guest
« on: December 08, 2009, 06:22:36 pm »
hi i want to know if someone can help me with this project...
i want to build a 555 ( the classical timer ) with discrete components like resistances and transistors...
but i cant find any good schematic description...
for example this that i have found...
https://sites.google.com/site/precisionaudiotv/_/rsrc/1244249588567/Home/aprendiendoplus/555_2.gif
i think the schematic is all right but in the list of the description of components theres some confusion...
for example...
Q1 N5 5 N7 1 NP
Q2 N1 6 N6 1 NP
Q3 N1 N6 N8 1 NP
Q4 N5 N7 N8 1 NP
Q5 7 N16 1 1 NP
Q6 N17 N14 1 1 NP
Q7 N1 N1 N3 1 PN
Q8 N17 N1 N2 1 PN
Q9 1 N5 N2 1 PN
Q10 N5 N5 N4 1 PN
Q11 N11 N20 N9 1 PN
R1 8 N3 4.7K
R2 8 N2 830
R3 8 N4 4.7K
R4 8 N9 1K
R5 8 5 5K
R6 8 N22 6.8K
Q13 1 2 N10 1 PN
Q14 N14 N10 N11 1 PN
Q15 N13 N12 N11 1 PN
Q16 N13 N15 N12 1 PN
R7 N14 1 100K
R8 N13 1 100K
R9 N15 5 5K
R10 N15 1 5K
R11 N8 1 10K
Q17 N16 4 N18 1 PN
Q18 N19 N17 1 1 NP
R12 N18 N20 5K
Q19 N20 N20 8 1 PN
Q20 N21 N20 8 1 PN
Q21 N21 N19 1 1 NP
R13 N17 N21 4.7K
Q22 8 N22 N23 1 NP
Q23 N22 N21 N24 1 NP
Q24 8 N23 3 1 NP
R14 3 N23 3.9K
Q25 3 N25 1 1 NP
R15 N25 N24 220
R16 1 N24 4.7K
R17 N24 N16 10K
D2 3 N22 D
D1 N18 N19 D
.MODEL NP NPN(BF=125 Cje=.5p Cjc=.5p Rb=500)
.MODEL PN LPNP(BF=25 Cje=.3p Cjc=1.5p Rb=250)
.MODEL D D(Is=1e-12 Cjo=1p Rs=5
this is the list of components...
how can i go to the electronics store and ask for this transistor???
Q5 7 N16 1 1 NP
with out to have to read a thousand pages of data sheet of every transistor that could be the one i look for...
and the worst is that this is the best schematic that i could found...
so if someone can help me telling me which are the models of these transistors and the diode...
it will help a lot...
or if someone can help with an other schematic it will be great...
or anything that can solve this will help a lot...
i really love the <3 555 <3
please help me...
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: 555 with discrete components...
« Reply #1 on: December 08, 2009, 06:32:00 pm »
Simple answer is you won't find the schematic your after and no you can't build it just as simply as that. Whicle its a great project of reverse engirneering why do you want to do it ?
your best bet is to take it one step at a time, the block diagram of a 555 is a window comparator, an SR latch and a discharge transistor. so you could use a dual comparator IC and a Latch ic and the neccesary external parts to make an equivalent.
if you want to come down farther than that then find out how the comparator is built and how the SR latch is built.
if your really fixed on this remember: its not about replicating the chip's diagram itself but building a descrete circuit that does the same thing so don't try to understand the "equivalent" diagram but how it works and design the solution to that.
but again WHY ???
walterdelbono
  • Guest
« Reply #2 on: December 09, 2009, 05:00:53 am »
because if i buid it i will learn a lot...
and there's a very famous homework in my university for the more advanced students...
i'm not advanced but i will be ...
so i think it's good to build it now ...
and in my country we are in holidays ...
so i decided to start the project...
thanks a lot for the help...
when i start the project yesterday...
jaja...
i thought that if the schematic way doesn't work i should take way of making the logic gates by my self...
because i want to make it all with discrete components...
if some day i can build it i'm gonna put it in the wall of my room...
jaja...
thanks simon i will keep on working on it...
GeekGirl
  • Guest
« Reply #3 on: December 09, 2009, 05:18:37 am »
Your list of components is not a list of parts to buy, it is a spice list for simulating the 555 function in something like Pspice.
walterdelbono
  • Guest
« Reply #4 on: December 09, 2009, 05:31:00 am »
yes i get the schematic from a tutorial of spice...
because it was the best schematic that i found...
bmwm3edward
  • Guest
« Reply #5 on: December 09, 2009, 06:36:10 am »
Sounds like a homework assignment.  Do you need help with your homework?
Offline Simon
  • Global Moderator
« Reply #6 on: December 09, 2009, 07:58:25 am »
you can't follow the spice schematic for biulding it from descrete components, like i said work from the block diagram not schematic diagram and build the blocks from descretes then you will have built a descrete 555
Offline Zero999
  • 0999
« Reply #7 on: December 09, 2009, 10:57:48 am »
You'll definitely learn a lot more by looking at the block digram and designing your solution to each sub-assembly than blindly building the internal schematic.
The block diagram can be found using Google.
Offline qno
« Reply #8 on: December 09, 2009, 11:15:02 am »
Hi Walter,
You can download the book of the inventor here.
http://www.designinganalogchips.com/
Good reading during the holiday's
Why spend money I don't have on things I don't need to impress people I don't like?
walterdelbono
  • Guest
« Reply #9 on: December 10, 2009, 06:19:35 am »
awesome book...
 ;D
:)...thanks everybody for the help...  :)
Offline Simon
  • Global Moderator
« Reply #10 on: December 26, 2009, 09:17:21 pm »
so hows it going ?
Offline jahonen
« Reply #11 on: December 29, 2009, 12:09:25 pm »
Linear Technology LTspice IV has discrete 555 example circuit in program installation directory, ...examples\Educational\NE555.asc. With that you can easily experiment with the circuit. I quickly tried changing the transistor models into BC847B (NPN ones) and BC857B (PNP ones), and the circuit still worked ok. I guess that just about any common small-signal transistor will do just fine. Although I'm not sure if there is a need for a matching the transistors. The matching is quite good between transistors in IC die.
Anyway, like already said, there is not much sense about building the discrete 555 in another sense than just educational.
Regards,
Janne
« Last Edit: December 29, 2009, 12:12:44 pm by jahonen »
walterdelbono
  • Guest
« Reply #12 on: February 26, 2011, 06:09:24 am »
i found iiiiiiiiiiiiiiiit...
http://www.ohmpie.com/hm555/
Offline Simon
  • Global Moderator
« Reply #13 on: February 26, 2011, 07:40:17 am »
I never knew figuring it out was supposed to be so long winded, i mean the contents of the 555 is well documented
Offline Lawsen
« Reply #14 on: March 23, 2011, 04:58:33 am »
I can look it up in my electronics school era books.  Like the rest of the group said, what is the purpose?  It was my first experience with TTL oscillator with a square wave output and useful for function generator and TTL logic controls in home made robots.  The timing is not as precise as a quartz oscillator or other standards.  I do remember a schematic diagram on the data sheet in one of my books.  You would be better off studying electronics for a projects book than trying to figure the insides of a 555 chip.  The 555 chip is used in the switching power supply in the East German Aus Juna Zeiss Laboval 4 microscope.  I love the high eyepoint eyepieces on it.  The power supply is a hum sound.  I like the quiet Olympus power supplies and the quiet Carl Zeiss KF-2.  These are all entry level, lower end microscopes that I use in geology era.  Old Zeiss Junior petrographic microscope has linear transformer power supply, that is absent of semiconductors.  Newest microscopes have LED and electronic power supplies, which I cannot afford them.  If I get some sleep and have time, then I will look for that schematic diagram in my books and post it on the gallery section.  What is the purpose?  I rather you buy a laser diode kit and build that and learn about that circuit than this.
http://i-fiberoptics.com/lasers.php?cat=laser-kits&sum=1642
Lawsen
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #15 on: March 23, 2011, 12:22:02 pm »
There is much to be gained by recreating someone's old work, mostly education in linear technique.  Its the same way, many formal school curricula still ask students to recreate all the key theorems: Nyquist, Maxwell equations, small signal equations, etc., to be familiar with it as an exercise.  Likewise, hobbyists and more, remake endless power supplies, amps, and function generators, what's the point?  You can buy it cheaper than make it.  Its for education, skill building.
Now, try to make your own transistor. Gives you a new appreciation for something you can buy for 30c.
http://blog.makezine.com/archive/2010/05/how-to-roll-your-own-nmos-transisto.html
« Last Edit: March 23, 2011, 02:30:55 pm by saturation »
Best Wishes,
 Saturation
Offline neoone
« Reply #16 on: March 23, 2011, 01:52:41 pm »
I think it's a grat thing to reproduce such legends as 555 with discrete parts. I'll put it on my list of gadgets to make that serve no purpose other then being there and maybe to show of to my friends ;-)
It would be even more interesting to make it using tubes ;-)
BTW, home made transistors rules ;-)
Offline the_raptor
« Reply #17 on: March 23, 2011, 04:12:15 pm »
Pfft making your own transistors? I saw a video of a guy the other day making his own tubes!
Offline Lawsen
« Reply #18 on: March 24, 2011, 01:56:24 am »
I have posted my report of inside the 555 in the schematic section of the gallery of this magnificent TTL astable multivibrator orginially by Signetics.  I left out the R-S flip flop part of the circuit.  Tim Williams has a great web site of the for building an R-S flip flop with discrete NPN transistors.  There is a schematic diagram for vacuum tubes R-S flip flop, too.  Surf here:
http://webpages.charter.net/dawill/tmoranwms/Elec_Flipflop.html
Lawsen
« Last Edit: March 24, 2011, 04:30:22 am by Lawsen »
Offline neoone
« Reply #19 on: March 24, 2011, 12:25:27 pm »
There was a guy on polish board elektroda.pl few years back who made tubes but I think it wasn't so sophisticated. Very nice indeed.
Making 555 on tubes hmm, maybe after 10 different project that need to be finished (like Tesla coil for example) ;-) The costs of such circuit would be quite high though.
« Last Edit: March 24, 2011, 12:32:05 pm by neoone »
