I think one way to do this is to rectify the signal with a full-bridge-rectifier and Smooth the signal with a capacitor. Afterwards you can use a cheap Buck Converter to step down the ~14V DC to 5V DC
Bridge rectifier and smoothing cap is how it's done in the locomotives, so that should work.
How does a signal that runs +&- qualify as DC? Noob here, but this is the first I have heard of rectifying a DC signal.
Hey guys,Another question to do with model railways, but much more "purely electronics".I'm wanting to power a microcontroller board (5V) from my DCC power supply. This is a 14-16V DC variable square wave supply (see image below). Which kind of power supply would be suitable for this?Cheers in advance!
What frequency is the signal?You might need to use a faster bridge rectifier, than what would normally be used for mains frequencies. The filtering capacitor can probably be quite small though.
How much current is required at 5VDC?Does anything powered from the 5VDC supply need to look at the duty cycle of the 14VAC input?
Is the OP's "DC" spec just a typo, or is this an actual form of DC.
Quote from: Hero999 on February 12, 2018, 04:48:29 pmWhat frequency is the signal?You might need to use a faster bridge rectifier, than what would normally be used for mains frequencies. The filtering capacitor can probably be quite small though.The frequency varies depending on the digital signals, but nominal signals are 58µs duty cycle for high bits, and 100µs duty cycle for low bits.See https://dccwiki.com/File:DCCSIG.PNG for the diagram :-)Quote from: Hero999 on February 12, 2018, 04:48:29 pmHow much current is required at 5VDC?Does anything powered from the 5VDC supply need to look at the duty cycle of the 14VAC input?The 5V supply is going to supply microcontrollers (PICAXE), which in turn have switches attached as well as multiplexed LEDs controlled through standard transistors. The only strange one is a set of PNP and NPN MOSFETs which control the solenoid point motors. The supply for them is separate however, the 5V is only to actuate the MOSFETs.Hope this helps :-)Sent from my ONEPLUS A3003 using Tapatalk
Quote from: Old Printer on February 12, 2018, 04:41:45 pmHow does a signal that runs +&- qualify as DC? Noob here, but this is the first I have heard of rectifying a DC signal.It's certainly an error. DCC stands for Digital Command Control.https://dccwiki.com/DCC_PowerQuote from: danners430 on February 12, 2018, 05:11:54 pmQuote from: Hero999 on February 12, 2018, 04:48:29 pmWhat frequency is the signal?You might need to use a faster bridge rectifier, than what would normally be used for mains frequencies. The filtering capacitor can probably be quite small though.The frequency varies depending on the digital signals, but nominal signals are 58µs duty cycle for high bits, and 100µs duty cycle for low bits.See https://dccwiki.com/File:DCCSIG.PNG for the diagram :-)Quote from: Hero999 on February 12, 2018, 04:48:29 pmHow much current is required at 5VDC?Does anything powered from the 5VDC supply need to look at the duty cycle of the 14VAC input?The 5V supply is going to supply microcontrollers (PICAXE), which in turn have switches attached as well as multiplexed LEDs controlled through standard transistors. The only strange one is a set of PNP and NPN MOSFETs which control the solenoid point motors. The supply for them is separate however, the 5V is only to actuate the MOSFETs.Hope this helps :-)Sent from my ONEPLUS A3003 using TapatalkYou need to measure how much current your circuit draws, if you can't predict it.The maximum frequency is high enough to wrarant something faster than the 1N4002. Use the UF4002, which is much faster.If the current is low <a few hundred mA, a linear regulator, such as the LM7805 will do. For higher currents, a large heat sink will be required, so it makes more sense to use a switched mode regulator and Schottky diodes for lower power loss. Fortunately there are some ready built switched mode regulator modules, available at a reasonable price. See the link below. Cheaper can be bought from Amazon, ebay etc. but a electronics distributors tend to give more product information and a shorter lead time.https://www.mouser.co.uk/ProductDetail/CUI/VXO7805-1000?qs=%2fha2pyFaduiEIMOeRYVCgIh28VRZWvYzaKIzMz0E4Jjizkg%252bdHgklQ%3d%3d
