Well, here it is!
I use the image on this post
https://groupdiy.com/index.php?topic=59590.msg756894#msg756894You could check the explanation there and ask again, I mention 8 bypass caps, because the discussed design used two output opamps as a differential drive, so paralleling 2 caps for each position, 2 opamps, 2 rails add up to 8 caps, call it two in a simpler design as the pict. Seen it from now, 6 should be fine as the bigger ones could be shared and further away from the opamp, but still between output and load as I'll explain.
There it is an inverting stage, but look how it looks like a differential amplifier, if rG1 and rG2 were actual resistors and not parasitics of the PCB. If this is the last stage the PS ground should be connected to the bypass caps and rG1 to the a previous stage's bypass caps. Bypass caps might bring noisy ideas to your mind but they are the ones that carry the signal current from rails to ground, so think them as signal decoupling caps, as ac coupled current signals, going from opamp "vcc/vee output" to the load or receiver reference ground.
If it were a non inverting amplifier, swap the input with the rG1-rG2 node, leaving the non inverting input to the input as it should and the resistor from the inverting input to the rG1-rG2 node.
With this you should see how the ground follows the signal, if your ground is messy you might get crossed resistances along those 3 and even some between this circuit and adjacent ones. Then, how to integrate this to a ground plane is kind of tricky, but think in component placement so it behaves like this, leaving the non inverting input closer to the input and the bypass caps between the opamp and the output, close to the opamp, and close to the output signal trace. As I explained in the original post this is how you squeeze the best THD+N figures of the given opamp/circuit.
JS
PS: along this topic I messed with decoupling caps and bypass caps, calling decoupling to what it should been bypass, so did the guy who wrote the datasheet. Decoupling os for AC coupled signals, bypass is from rails to ground, close to the opamp as a dedicated current path.
