Hi there,
I'm building a MIDI enabled device. The first prototype worked very nice, so I went on and build the second iteration that corrects all sort of mistakes on it. That time, the MIDI signal is not pickup and after some digging, I've found that the ouput of the 6N137 optocoupler was very low and "dirty" compared to the first iteration. Moreover, the signal low is not always at the same level. I'm wondering if anyone can provide any advice where to look for ? Could it be the 6N137 itself that could be failing ?
I've attached two screenshots from my oscilloscope. Channel one is the 6N137 input, channel 3 the ouput.
Also, I've attached the schematics used for MIDI I/O, based on
that page. Although there is some difference, that wiring has always worked through all the development stages and on the first prototype without a glitch.
Thanks,
LTourist
