I’ve never tried doing anything like that, and I must admit I was thinking that if one of the drivers in the package is slightly slower than the others, then it could still be pulling its output low while the others start pulling their output high. But if the outputs are connected in parallel, this would temporarily short the Power Supply. But in reality the transition time of the devices isn’t zero so it’s unlikely that you would get a full short if this was the case anyway.
