Do you convert the voltage from the transformer to DC before it gets to the 7808 ?
Transformer output is AC, regulators work with DC voltage. You have to use a bridge rectifier or at least one diode and then some capacitors to get DC voltage from the transformer.
Is the output of the transformer 10 volts DC AFTER rectification and after using a capacitor, or it says 10 volts on the transformer label?
Regulators in the 7800 family need 2 volts ABOVE the output voltage to work. A 7808 will need AT LEAST 10v to output a stable 8v. This is mentioned IN THE DATASHEET.
for example ,when i bought a soldering station the ct -936..i got it with the knob broken ..
A knob can be broken during shipping, you can return a broken product and ask for another one or your money back. You're in European Union, so you order something and have it shipped to you, you have the right by law to return anything for your money back, no questions asked, within 10 working days of your purchase. if the seller doesn't agree to send you another knob or change your product, ask for money back within the 10 days allowed by law.
