Author Topic: 93LC46/56/66 Serial EEPROM - A Few questions.  (Read 3037 times)
Offline erikhedbTopic starter
« on: February 01, 2015, 06:43:47 pm »
Im trying to dump the content of a salvaged ATC 93LC46 Chip. The 93LCXX chip seams to be very common and also made by many different manufacturers.
http://pdf.datasheetcatalog.com/datasheet/Ceramate/mXruxvr.pdf
Have done a few Arduino and AVR projects but cant get a grip ion this chip.
I do know that I must shift out bits with commands and then shift in bits to read the EEPROM.
byte READ  = 0b110;                //read instruction
byte WRITE = 0b101;               //write instruction
etc
In order to read I must shift out the read instruction together with the adress to read. After that shift in the data in that adress.
The data sheet specifies:
START BIT 1
READ 10
ADDRESS A5 A4 A3 A2 A1 A0
DATA D15 - D0 25
So what do I shift out to get something in?
How do I specify the different adressess?
A0 = 160 = 10100000
A1 = 161 = 10100001
Also, how are the memory organized. A0-A5 is just six differend values.
Can someone please point me in the right direction?
/Erik
More, its a petty the timing diagrams are so short, a full low-high sequence would explain it all.
Also, is this a SPI device? I suspect it might be.
« Last Edit: February 01, 2015, 07:01:48 pm by erikhedb »
Offline elgonzo
Re: 93LC46/56/66 Serial EEPROM - A Few questions.
« Reply #1 on: February 01, 2015, 06:51:12 pm »
A0 = 160 = 10100000
A1 = 161 = 10100001
/Erik
Seems you have a misunderstanding. A0 ... A5 are address bits. Thus, you have 6 address bits, giving an address range of 0...63.
Also, read the datasheet carefully, especially about timing and necessary clock impulses. It might be that only 6 address bits are used by this chip but the protocol still demanding 8 (or less/more) clock impulses as if there were 8 address bits...
« Reply #2 on: February 01, 2015, 07:11:51 pm »
Ah,
So A0 is address bit 0 etc.
So: 000000 is the start address and 111111 is the end address?
Also 1024 / 64 = 16 -> Shift in D15-D0  ie data bit 0 to Data bit 15.
Thanks
Offline elgonzo
« Reply #3 on: February 01, 2015, 07:14:53 pm »
Yupp.
Offline woodchips
« Reply #4 on: February 02, 2015, 05:39:35 pm »
Don't know which manufacturer you have, but these chips can work in 8 or 16 bit mode. And some will only work either in 8 or 16 bit mode.
