This looks like it's a flyback converter (Single input transistor) In which case, the startup resistor is a prime candidate for going o/c or high value. Usual clue is that without the small current this draws, the reservoir cap (big electrolytic center of board, mind your fingers as it can have 350v on it) will remain charged for a long time after power is removed.
Likely it's one of the larger resistors stood on end, R3 or its sleeved neighbour. Will have a value somewhere between 47k and 1M. You can't measure it in circuit.
The other larger resistor, R17, 0.47 ohm, is likely for current sensing. It's also quite common for resistors of this type to 'dry joint' so check the soldering.
Some of the larger connection pins near D11 and L2 on the underside (possibly the transformer) also look a bit dry-jointish.
