I looked at this expensive device: LT3649 (
http://cds.linear.com/docs/en/datasheet/3649fa.pdf)
It is one of these rail-to-rail switching regulators that offers TRUE 0v output because they use the same current source reference in their gain amplifier as the famous LT3081 and his siblings.
It is a massive 12$ device so not very economical! However, the other solutions like LT8611,14,40-1 are around 9$ so they are the same. The difference here is that LT3649 can be controlled straightforward more than the others... no tracking no negative supply... nothing, which is a big advantage. The other rail-to-rail regulators are only 15v max output which cannot do the 25v I want (this one 60v max! @ 0.5v drop @ 95% efficiency).
It offers current control and monitoring! so it is a power supply in a package. Control method is so easy, only resistor feedback. I still don't know if it is constant current (fixed) or just limit. very important to know.
I aim to make the lab supply capable of constant voltage, constant current source, current limit , and if I could constant power. To compete other designs because the price is gonna be a lot thanks to 12$ device.
Another solution that I came up with is the use of cheap high current pre-regulator followed by an efficient LDO that goes to 0v such as LT3083 @ 3A. However, this device itself is not cheap too (8$)... even LT3081 is not so cheap (5$) and offers only 1.5A and it is not an LDO so paralleling 2 of it is not efficient and will require a heatsink... I don't want to use any heatsink at all!
