I've been reading on transistors and I'm focusing on the common emitter configuration now. However I have some questions, newbie level, that I'm not sure about.
Let's suppose I want to drive a 1W speaker with 8 ohms resistance. To get the 1W you need 0.35A and 2.8V on the speaker. Now, if I have a Vcc of 12V, the questions are:
1) To confirm, I'm supposed to set Vc to 1/2Vcc which is 6V. I must set the circuit so that it doesn't exceeds the 8.8V right? given the 2.8V required by the speaker.
2) Does the variations in current caused by the input are going to be absorbed by the speaker and so Vc will stay always the same?
3) I'm not sure how an AC input (through a capacitor) would affect the DC in the base of the transistor. If let's say the input AC voltage is 2 Vpp, and the DC in the transistor's base is set by a voltage divider to let's say 3V. Is the DC going to start oscillating over 4V and 2V?
