The problem with assumptions is there based on what the person making the assumption already knows. Their brain flashes through all their past knowledge and experience in a moment and up pops a value. They won't be able to give you a 3 seconds explanation because sub consciously it's been done for them and there told from inside that it's gonna be X.
This really is a major problem, particularly in books.
When i was taught programming with pascal and machine code, electronics and all other things i wanted to understand i was in a fortunate time.
Books in them days, the 70's and 80's described principles and examples in simple to understand ways, say for example programming C and pascal. If you look at today’s books you have a few pages of 'for' 'while' and 'if', then the rest goes into brain deadening masses of unexplained dribble.
If you get hold of the 'old' books, they give pages and pages of clearly described code full of comments and what you shouldn’t do and why.
Same with today’s electronics books, there written by people who just want to churn out what they know, get the 'old' books from the 50's and 60's, even valve based, and the detail and explanations is beyond belief.
A lot of the foundations and basics what you may want to learn is no longer available in today’s publications or on the internet, as you've discovered it's all assumed you know it all. It has gone with those that knew and have since died. As an example, about 25 years ago i wanted to build my own studio flash units, at that time 'bowens' ruled supreme, you couldn’t by the tubes or the caps or anything to build these big beasts. There was no internet, and the library ruled. But the only info i could find, very little but very detailed was in books from the 50's. I found a small company that made the tubes, went and fobbed my way in and tried to make out i knew what i was talking about. From that i got the name of a designer, got his phone number and phoned him up, The amount of info he was giving me just went on an on, after 10 minutes i was forgetting what he had started telling me, so i hung up, grabbed a tape recorder, phoned him back, apologized for being cut off and then recorded over an hour of information that to this day i have never heard again. Did you know that high power studio flash units can self trigger in complete darkness, illuminate the room with almost no ambient light and they never will.
Another thing you may find is that you will learn more from what you 'notice' than from what your told.
ps , get the old books, i have books from librarys that were put out of circulation and had their hard covers ripped from them do dissuade people from taking them from the bins, old, damaged but worth their weight in knowledge that is now disappearing.
