Without r2, what happens when the charger is removed? The voltage on the VDD net will be floating at a point where the diode leakage and current used by the charger ic are equal. The mosfet may not be turned on fully or at all, adding a diode drop between the battery and the load. With the pulldown, VDD goes to ground, the mosfet his turned on fully, and the load gets full battery voltage.
