im wondering if this chip could be used with pretty low rdson fets and its power supplied externally it doesnt need much so a small bridge rectifier from the main ac feed maybe? high power losses would be minimal too
Very unlikely. If you've ever looked at designing a FET bridge, there's a very tight relationship between the AC side and DC side.
Supplying a separate low VAC for the charge pumps, even IF you could line up phases etc is unlikely worth it.
Basically, the "control chip" watches the VAC level coming in, compares it to the DC level, and once it becomes +ve, switches the FET.
On higher currents, it waits until the onboard Shottky conducts before doing so. You can see it in the waveforms.
If you don't do this, at the instant of switch-on, depending on cap storage = app INP/OUT impedance, the VAC can suddenly DROP
again, below DCV, in which case you now have current feeding BACK into the Transformer (in this case). It's only a short time, but
can cause huge current spikes / losses. I'm about to make up a bi-dir current sense and really get a better picture.
Having made these devices in the past (using optos, external charge pumps and isolated high speed logic control), it's a really
very tricky design, which is why I was so impressed with it.
ALL it needs is a 0V side referenced shutdown pin (maybe Ver2?) and it'd then truly be AWESOME !! I've tried to email them with
suggestions, but it's impossible to find a tech feedback addy. You would have thought?
Why do we need this? O/Temp, O/Current, O/Anything SHUTDOWN ! The perfect oN/oFF control of up to 20-30A with a 10uA 3V signal !!!
woohooo heaven.
