This is a chip built for PoE, to replace the 70V diode bridge present at every PoE Powered Device....
I disagree with you here .. I don't see many PoEs needing to supply 20A without needing a heatsink.
It's exactly what it says it is - a POWER Supply bridge rectifier replacement, and they are working out perfect in our products.
Your PD70244 is NOT in the same ballpark. It's 1A (not 20A+), has 160mR inbuilt FETs (I'm using 0.9mR !!) AND it drives these
10,000pF NFETs absolutely fine to 600Hz (and beyond IF I limit the current under 20A !!).. which is ALL I (we) need for DC rectification.
I have no idea why you think it's for PoE
