You are not doing anything wrong. 50 MHz bandwidth means that the signal that oscilloscope is showing, at 50 MHz, will have -3 dB (or 0,707) of the actual signal amplitude. Oscilloscope is still capable of showing signs of higher frequencies, but their amplitude will be lower the higher you go.
Your scope has a sampling rate of 1Gsps. So you could even maybe see a signal of 500 MHz, but it will have very low amplitude (if any) and will only show it as triangles.
