Author Topic: A question of gain notation.  (Read 853 times)
Offline AethelstanTopic starter
« on: February 10, 2018, 04:08:34 pm »
Hello, up front I must state this question does relate to an assignment I am working on. I am converting gain for op amps between arithmetical and dB, and I understand the maths but I am a little confused regarding the actual notation for the two scales. If I have a gain of 20dB, is that simply G=20dB, or do I use the unit for power gain of GP? If I use that, do I use the notation of GV for arithmetical gain? Or, should I simply use G and the unit of dB or unit-less V/V signifies which type of gain I am talking about?
Offline CatalinaWOW
Re: A question of gain notation.
« Reply #1 on: February 10, 2018, 04:39:09 pm »
In my experience there are no robust conventions for this.  It would save some trouble if there were.  In documentation I generate I explicitly define the notation I use.  In documentation I am reading I am very cautious about assuming usage, and often have to run a series of calculations to figure out the authors usage.
If your professor has not expressed a strong preference just document what you do.  (Run through some test cases to make sure you are self consistent.)
The following users thanked this post: Aethelstan
Offline tggzzz
« Reply #2 on: February 10, 2018, 04:48:07 pm »
I would use "gain of 10" or "gain of 20dB". If I thought it might be ambiguous or might clarify a point, I might use "voltage gain of 10" or "gain of 10V/V".
Offline Zero999
  • 0999
« Reply #3 on: February 10, 2018, 04:58:34 pm »
I've always used AV for voltage gain and just A for power gain.
In any case, it should be fairly obvious whether voltage or power is being discussed, by the context.
