Is it possible to get an oscilloscope to trigger on any repeating waveform?
I have had no problem setting my trigger until i started looking at the voltage output of a VFD driving a 3 phase induction motor.
I could see the pwm switching when i stopped the scope but could not seem to get a stable trigger at all when running. I tried HF reject on the trigger setup and adjusted the hold off but the thing would not stay still. I had hoped to view one complete cycle so i could see how the pwm changes on start up.
Any ideas?
Maybe use DC coupling on the channel to remove the "wobble" of the baseline as a start (if that's possible given your operating voltages).
You should be able to use DC coupling on the trigger, with the level you have shown, and the holdoff set to something between 12 to 20ms.
Of course, if you're only interested in the startup behavior, then a single shot capture is the way to go (holdoff doesn't apply).
