I have a single supply. If I'm connecting several op amps together for an audio guitar effects pedal, should I AC couple each stage? I have an input buffer, clipping stage, filter, and output buffer implemented with a 4-op amp IC. I remember reading somewhere that if you don't AC couple everything, you'll get more noise as the when DC is passed along and amplified. Do only gain-producing stages need this treatment?
Thanks,
Carl
