To me it sounds like you want to current limit the output, which will change the voltage, but only when the current limit is exceeded.
If not care to explain a little clearer,
As for the how, wiring a bipolar constant current load inline would be one of the simplest ways, (this is an active device). Other than that would be something nastier like applying a dc bias the transformer to control the saturation current.
