@Hero999, these modules are used in mid/late 90's cars. ex. Citroën Xsara, Xantia, Peugeot 406 that i know of. They often fail short, and the blower then runs at full speed.
Afaik they are only fitted in cars with AC, so the climate ECU can control the blower speed. Non AC cars have the usual resistor-pack, and 4 fixed speeds.
@fadyeid, Yes if the speed can't be regulated, the transistors are shot.
Note, if you replace them, there is a little disc thermistor between the heatsink and PCB, it is very easy to loose when you're busy replacing the transistors.
