Ok, so my torrild transformer spec. is: primary 230v, secondary 24v 80VA. I have 16.4 feet of 20 awg nichrome wire. The chart says 5.1 amps is needed to heat 2 feet of straight wire to 315C, but devided by 2 if element is coiled. I should have enough wire to coil it, as my heating strip only needs to be about 9 inches long. Will my transformer be big enough for this job? Im planning on rectify the ac to dc, and use a 555 timer to pulse a transistor, that will power the heater element.
