Hi All,
First post so excuse my ignorance if I miss any rules or regulations. Heres my scenario that i've been fighting with for quite some time. Still haven't gotten really the magical answer. I am working with a Logic Level (5VDC), and industrial level (24VAC) system. I am using a rugged built arduino to control a set of 8 inductive coils to perform various operations on an industrial machine. Works great 85% of the time. However after running for some time, the LCD Display beings to crap out. Aka, starts displaying garbbled text. I have been working on this for over a year now with no fix just yet but I'm very stubborn so it'll give in eventually. I have tried using a MOV, although I do not know the values of it off the top of my head I will get those if requested. I do not know the exact size of the main coil that is causing me issues but we'll get to that. I recently just purchased an oscilloscope to help me troubleshoot the issues i've been having and this is what i've found so far. I do have a 200mV ripple coming out of the DC line. This ripple is not there if I do not run the main conveyor motor.
I have unplugged the relays that go to the coils to see if they could be picking up the noise even though they do not connect to the motor directly. This did not change anything. I left the power supply (a typical wall wart) unplugged with the noise still on the DC supply line which leads me to believe it may be an EMI issue, but I don't know if 200mV is within reason for a typical ripple?
Another scenario i've been working on is ordering the right MOV for my circuit. Its all 24VAC so if the math from the various websites is correct I should be looking at a varistor with a 36VAC maximum. Correct? Well that was set in stone in my thought, till I looked at the scope and it says my AC wave is typically 40VAC even though its a 24VAC system. Obviously this is probably cause its measuring wave top to wave bottom. So would the 36VAC varistor work or should I be looking at a varistor with a 40VAC rating?
Please see attachments for scope images. In the first image I show the ripple coming through my DC power supply. In the second image (pic_12_1), I show the voltage spike when triggering the coil off.
Thanks in advance for your time in reading this giant post.
- Matt
