That's an ICL7106 (or equivalent) based meter. They don't normally have a voltage regulator as their input voltage is fairly flexible (9v battery range). I don't see a reverse protection diode either. If you really want to keep it, you could remove the glob-top IC in the centre and solder a new one to the pad footprint, but whether it's worth it depends on how cheaply / easily you can get a replacement.
How do you desolder \ remove the glob? do you need something special?
The glob is epoxy so I would think a smelly poke with a hot soldering iron might do the trick. It might be a bit time consuming though as you need to get it flat to be able to solder on a new chip. The die would probably come off the same way, make sure you clear all the bond wires to avoid shorted traces.
I really wouldn't consider it until you've priced a replacement 7106 and made sure it's less than a replacement meter. Nothing to lose at this point however.
Edit: just a quick check on eBay and the one listing for the PM438 is quite pricy whereas Chinese ICL7106s are quite cheap. I don't know where you bought it though.
Alright, I'm going to use an crappy tip on my soldering iron and setting it to the max tempeture, I'm also going to put an tape over the board so nothing will be damaged.
The metering panel is dead now, so I cant ruin it more, might not work out but who cares, 7106 cost nothing compare to this panel which the only seller that ship to my country is this one:
http://www.aliexpress.com/item/Digital-panel-meter-DC-voltage-measurement-Digital-LCD-header-PM438/32517120449.html?spm=2114.13010608.0.81.cwalhuand I also need to wait about 2 weeks to receive it.. if I can fix it for a couple of cents with a chip that my local electronic store probably sells then why not.
It is a cheap Chinese meter. Why not simply replace it??
its not that cheap. its 16$ for 5 of those - ~3.2$ for one - but there is only one seller that ships to my country and he is from hong kong so a lot of waiting time. also minimum order is 5..
+1 for digging with a very hot OLD soldering iron bit. Don't use a good one!
I'd mask off everything except the blob with aluminium foil over cartridge paper as a thermal barrier, taping down in a square round the blob with aluminium foil tape, (or Kapton tape if you stock it) so you don't mess up anything else on the board.
Use some small fragments of lump Rosin to improve heat transfer to the Epoxy. It also attacks and softens epoxy when boiling hot, so keep on scraping off what's loose and adding a little more Rosin.
Get the board cleaned up (or fail) before ordering any parts!
I will try aluminum foil + cartridge paper, hopefully it will work.
I don't have rosin
Just one other thought - don't cook the LCD on the other side of the board. Hopefully it's spaced off sufficiently.
hopefully it wont happen. there is not much I can do about it but I will try my best to not get too much heat.
I think we're hopefully about to find out, I'll be interested to see the result too. Please document and show us pictures ZeTeX.
I will!
Thanks for helping everybody!
