I am not a professional EE guy. My projects are just for fun, for learning, and to keep my mind active. I don't need to do any of them, consequently any equipment I use for them are not need based.
So, I don't really need more accuracy, but at times, I sure can use more accuracy.
For example, I was going to validate something I know is true, but I want to experiment and see for myself: such as resistors increase in resistance as it get hotter. I like to do a plot. I like to compare carbon film against metal film resistors. I like to compare if the drop between 20C to 10C is the same as 30 to 20C... I don't need it, but I sure like a more accurate temperature-probe. Until I get a good temperature probe, I can get to square-one with this project.
Right now, I am (re)doing an Arduino voltmeter (converting a one time volt logger to something I can use again). I can buy a DT830B for less than I spend on the project so far, and it would be more accurate, more flexible, and better protected than a a wire into the bare Arduino ADC. But just clicking BUY on ebay is not nearly as educational nor is it as much fun.
I don't really need a Porsche 911 Turbo, but I sure like to have one... I take that over even a Ferrari. I don't really need it... No one really need that much car. A Fiat or a KIA will get you from point A to point B just the same...
