it depends on what your doing, if you know your meter is accurate to those counts (remembering counts reference precision not accuracy) and for instance your confirming or calibrating some other bit of equipment those few counts may be important, for instance a frequency standard of 10.000000Mhz as opposed to 10.000070Mhz is critical to very high bandwidth applications, otherwise you have frame alignment issues,
same for resistance, perhaps your making a mega-ohm bridge to measure even higher resistances, those few ohms difference can really count
please recall most of us applying out skills in some way at our respective jobs and we are not all kiddies playing around with an arduino dev board and a linear power supply, some people actually need high accuracy measurements,
